Door adjustment
Chris
Door adjustment
Post by Chris » Tue, 28 Apr 2015, 12:21 pm
Can anybody tell me if both top and bottom door should go fully open together? On my Portafold if I hook the top door open the bottom door catches on it and won't go right back. Is it just a case if adjusting them?
Thanks,
Chris.
Re: Door adjustment
Post by Admin » Wed, 29 Apr 2015, 11:22 am
I would never recommend opening both doors together, as it rarely works out OK and you'll just end up with crunching and breaking fibreglass. I would always open the top door first, then the bottom one.
If the top half is open, the bottom should in most circumstances open wide enough to sit level with the top half, but it's a Portafold, so it may not work and it may sit in front of it.
You can buy hinge pin kits (http://portafold.co.uk/parts_and_spares ... n_kit.html) to refurb the doors, so that might help with the way they hang.
fuzzyface
Re: Door adjustment
Post by fuzzyface » Wed, 29 Apr 2015, 8:29 pm
How much adjustment is there on the door hinges? Those pins look the same as the ones fitted to my Morris van rear doors. The hinges are bolted through holes that are larger than the bolts giving quite a bit of movement to adjust. In an extreme case I have cut one of the brass balls in half and used a thin brass washer to space out the two halves of the ball.
Re: Door adjustment
Post by Admin » Wed, 29 Apr 2015, 8:51 pm
Yep, they're all very similar hinges. I initially thought they were all identical, but just recently someone told me there are different size brass balls.
But I'm quite sure the ones I have on mine are the same as on a Landrover.
fuzzyface
Re: Door adjustment
Post by fuzzyface » Thu, 30 Apr 2015, 7:51 pm
Yes, and the wrong size would cause alignment problems. I can see why I may have had so much trouble now. Something to investigate when I get a portafold. :)
