The Big 60th Birthday Party of the Portafold (12th International Portafold & Ansfold Gathering) (i.e. 2020)
Help us set a new world record at the big 60th birthday party!
Ironically, the current record is 59 Portafolds and Ansfolds (at the 2016 Newbury Retrofestival), so we want to smash this by getting well over 70 there next year. As of last year we have a new area that will take that number of caravans and the show itself is a fantastic event that will not disappoint. There really is something for the whole family.
So put the dates 7th, 8th, 9th of August 2020 in your diary now and get those dates booked off work early. Be part of a record breaking event that will go down in history.
Don't book direct with the show organisers, just contact me to get your pitch saved.
Hinge Pins Doors
Gordon McLaren
Hinge Pins Doors
Post by Gordon McLaren » Sat, 12 Apr 2008, 6:13 am
Anybody out their had problems with door hinge pins? well i did and the solution was easy. the hinges have a countersunk headed pin , with a brass ball and spring in the middle , and a locking tab and nut on the bottom. these looked vaguely familiar , and i found their the same as Land Rover series 2a door hinge pins . e bay to the rescue and they were fitted in under 1/2 an hour. doors now very smooth , no floating up and down when opening at all.
i have a spare set if anybody wants them , cost price + carriage
cheers gordon
alexdundee
Post by alexdundee » Wed, 18 Jun 2008, 10:13 am
A spare set as in 4 of them?
I would like them please, PM me how to pay and where to send the money.
http://www.alexdundee.com
http://www.hdvwclub.co.uk - Harrogate and District VW Club.
Grumm
Hinge Pin Doors
Post by Grumm » Tue, 24 Jun 2008, 3:41 pm
Hi Guys,
Gordon, I took your lead and got some off of Ebay.
I haven't actually looked at how they dismantle and go back on......
Is it easy?
Graham
Gordon McLaren
hinge pins doors fitting
Post by Gordon McLaren » Tue, 24 Jun 2008, 6:03 pm
very easy to remove old ones , 1- take thin bladed screwdriver or chisel , tap up folded down locktab , 2-hold pin from moving with screwdriver on top slot (scrape paint from groove first) , and with other hand use spanner or adjustable to remove nut . if nuts are rusted on use angle grinder to cut of the nut , covering fibreglass behind with thin piece of board to protect from sparks . 3- once nuts are off , the springs will fall down from the bottom part of the hinges. remove pins by lifting door upward and off , this reveals the brass ball sitting between the 2 halves.
replace the 2 new brass balls ,put door back on and drop down pins from top , spring comes over thread from bottom , compressed by lock tab and nut. tighten nuts , gently compressing springs , and adjust to suit , finish off by tapping over locktabs. you may find about 1/2 inch of thread sticking down , cut off or leave , whichever.
i replaced all four sets for both doors in approx 1/2 hour. it makes a big difference , their is no floating up and down and i find the doors shut considerably better. :D cheers gordon
Grumm
Hinge Pins Doors
Post by Grumm » Tue, 24 Jun 2008, 6:31 pm
Gordon
You make it sound very easy! I will give it a go..........
At the moment, both halves of the door catch each oher and a previous owner has not been too careful, causing a bit of damage.
Hopefully, this will help to keep the two halves "apart"
Graham
alexdundee
Post by alexdundee » Wed, 25 Jun 2008, 11:27 am
Thanks Gordon, I'll have a go this weekend.
Alex. 8)
Re: Hinge Pins Doors
Post by Admin » Sat, 10 Dec 2016, 11:41 pm
I now keep these hinge pin kits in stock, and I'm cheaper than anyone online or on eBay!
http://portafold.co.uk/parts_and_spares ... n_kit.html
Email me to place your order.
