by txfsealord » Thu, 18 Jun 2009, 8:27 pm
Hi all, I'm back! - the bloke who looks after my computer damaged its motherboard last Friday, trying to add memory.
It's been a long, weirdly quiet week.....
Tyres. If your van's loading, or overall weight, is on or near the 12cwt maximum specified for the towing-hitch, then it's also close-ish to the maximum load for the 4-ply tyres. As caravan tyres don't wear out very often, I think it's advisable to have 8-ply tyres like Matthew has, rather than the 4-ply car ones. That way, as well as better handling, there's a much larger reserve of loading capacity, so as the tyre's structure degrades there's less fear of casing failure. This degradation is a function of the tyre's advancing age (the molecules of the carcass lose their flexibility), there's only so much we can do to preserve them. It's a good idea to protect them from direct sunlight if your van's kept outside, & not to leave them standing in pools of oil or petrol - unlikely this, as these fluids aren't in caravans. The handling of the caravan is better on 8-plies, with less wallowing & wandering, again as observed by Matt.
In my case, it's quite easy to go over the 12cwt maximum weight as I've so much added gear with my van, & my wife likes to take enough food for our entire stay; hard on the old Morris, as well as the van.
8-plies, usually of Camac make these days, are quite a lot dearer than 4-plies. The 8-plies are marked 'Trailer' on their sidewalls, otherwise they look identical to the 4-plies. The section is 145x10 for both types. The 8-ply speed rating is lower, about 75mph I think. 4-plies are 85 or so; the small diameter means the wheels are going faster for any given speed than, say, 12" ones so the speed ratings are somewhat lowly.
As stated elsewhere on this site, these are both RADIAL types. Crossplies are measured differently. Their section is 5.20x10. It's illegal to use crossplies on your caravan if your car has radials on it, & almost all post-war cars use radials nowadays.
I hope this helps people's decision-making processes.
