Quilting
Quilting
Post by Ian » Thu, 28 May 2009, 12:46 pm
No, not a bunch of grannies making family heirlooms - the stuff on the sides...
Some previous owner kindly gave mine a coat, probably several coats, of white emulsion - gives it all the ambience of a victorian gents loo...
Anybody got any bright ideas on how to get the paint off, or, more probably, how they 'improved' their version of this DIY disaster?
Post by bigbird » Fri, 10 Jul 2009, 10:25 pm
Hi Ian, well mine was pretty lousy inside, and the fibre glass already needed repairing so I 'carefully' powerwashed it, it got the paint off and covered the lawn in dandruff!!...but..it did work!!
I hasten to add, I only did this to the roof, I didn't want to fill the unit up with water!! :shock: :lol:
Post by Ian » Sat, 11 Jul 2009, 10:37 am
I'm tempted to powerwash an area of the quilting to see if it will shift any of the emulsion - it can't do any more harm.......... can it? :? and the interior is devoid of anything that can be damaged.
Post by bigbird » Sat, 11 Jul 2009, 11:16 am
Is the quilting fabric, because if it is, you won't get the paint off??It worked bloomin well on mine mate, but mine was just paint on fiberglass, it saved a back breaking task! The ceiling was clean enough to paint over, although I wallpapered it with polystyrene paper. Have a look at my pictures of before and after...
Honestly, the one thing that grieves me in this whole process is the fact that I should have taken more time on things...but if I want to use it this summer, like I said before..'it'll do!!'
KorenM
quilting
Post by KorenM » Sun, 12 Jul 2009, 3:40 pm
You might regret that ! my van had polystyrene all over it when I got it it, and it was a nightmare to get off, and made a real mess. It had to be removed because it was mouldy behind.
I plan now to cover the lower walls with that table heat protector stuff and the roof with head lining.
Need to fix the car first though..........!
Koren
Post by bigbird » Sun, 12 Jul 2009, 4:07 pm
No sign of mould yet...I wait with baited breath...if it is a problem, fortunately it is on the roof only...
Post by Ian » Tue, 14 Jul 2009, 12:00 pm
If the pressure washing doesn't work (which, if I'm honest, I don't expect it to :( ) I suppose I could continue the theme(!) and paint it in a better colour.
I did toy with the idea of ripping the quilting out and replacing it with an insulation sceme I saw in the Haynes manual on building a motorcaravan. The builder glued 1" battens around the perimeter of the wall panels and then stuck close-fitting 1" thick insulation panels (I think it was polystyrene) to the walls and then finished it all off with 1/8" thick decorative wall-boards that he bought as new-but-surplus stock from a caravan-breaker. The scheme seemed to offer the advatages of lightweight construction and better insulation than the quilting. I haven't progressed the idea because of the prohibitive cost of travelling to the caravan-breaker in Yorkshire to pick the decorative wall-boards costing only a few pounds apiece.
Post by bigbird » Tue, 14 Jul 2009, 12:05 pm
Coo that sound fabulous. Mind you, I don't envy you cutting around all the curves inside. If you can do it, that will look great Ian!
Post by Ian » Tue, 14 Jul 2009, 12:12 pm
I was only toying with the idea for the walls, not the roof.........- that would be too much of a challenge :shock:
Post by bigbird » Tue, 14 Jul 2009, 2:05 pm
Grrrrrrr, roofs. Well, I wanted to paint Matilda today, then I realised that I'd left the foam rollers inside, despite the fact that we'd opened her yesterday and got some things out. So...I thought, do I tell OH, he's not going to be best pleased with me after getting up at 4.30 for work, then to have to come home and erect the caravan yet again.
I can do that....I thought, well with the help of my lad...lad finally emerged from bed at 1.00 and grunted something about the shower. I couldn't wait any longer I thought...so I attempted it myself, got one end up, then went to lift the other...b*gger it's too heavy and not high enough. Then I propped up the remaining inner fold with a stool. I lifted the other end, there was one almighty sway and the whole lot came crashing down.
All the headlining for the roof is wrecked, and I got moaned at by OH again for breaking her.
NOT A GOOD DAY. :cry:
