The Big 60th Birthday Party of the Portafold (12th International Portafold & Ansfold Gathering) (i.e. 2020)
Help us set a new world record at the big 60th birthday party!
Ironically, the current record is 59 Portafolds and Ansfolds (at the 2016 Newbury Retrofestival), so we want to smash this by getting well over 70 there next year. As of last year we have a new area that will take that number of caravans and the show itself is a fantastic event that will not disappoint. There really is something for the whole family.
So put the dates 7th, 8th, 9th of August 2020 in your diary now and get those dates booked off work early. Be part of a record breaking event that will go down in history.
Don't book direct with the show organisers, just contact me to get your pitch saved.
Sink fitting?
Sink fitting?
Post by bigbird » Mon, 27 Apr 2009, 5:23 pm
On buying our Portafold, we found that inside there was a switch for what we can only assume is to be attached to some sort of pump (missing) for water supply. There is an outlet pipe and an old plastic large water holder. The switch is a small plastic rectangular rocker switch that clicks when you press it. Having no experience of rigging up a proper sink with water supply, does anyone know exactly what we would require, apart from this switch and the water pipes we already have?
Pumped water
Post by txfsealord » Mon, 27 Apr 2009, 6:26 pm
Hi Bigbird,
When I did this job on my Ansfold a couple of years ago, I found that "progress" in the fitments sold for caravanners meant I wasn't able to find a plain spout for the sink. By this I mean that all shops keep combination double-tap units (hot & cold with pump switches for both) a few still had cold only (single tap which incorporates the pump switch) & the plain spout I wanted was no longer supplied. With a plain system, there's no valve on the pipe (spout) over the sink, when you operate your switch the electric pump pushes the water out of the tank, through the spout. With the single 'tap', there's a switch as well as the valve so turning the tap on switches the pump on simultaneously, this supersedes your switch.
To use your switch, you'll need the fresh-water container, a water pump which can be bought separately from caravan suppliers, a sink with drain (ditto), inlet & outlet piping & the spout which can be a bit of copper pipe bent over to aim the water-jet into the sink. A 12v electric supply runs the pump (I have a small car battery fixed in my 'van which also powers interior lights). Without the tap-valve the pump-jet will be very fierce as all the pumps currently available seem capable of powering a shower! Certainly they empty the water container pretty fast. You could regulate the electric supply by including a rheostat in the circuit to 'turn the pump down a bit', but this would involve finding a rheostat which matched the pump. I found it easier to use the switched tap.
I hope this answers your question,
Post by bigbird » Mon, 27 Apr 2009, 8:06 pm
Wow, steve, thank you so much for all that info, I won't pretend that I understand all of it, but I am sure that my husband will. That is so helpful! I've seen a sink with a fold down tap on it that came out of a VW, it looks like it will fit, I'll get hubby to read all this info and check that it's the right type of fitment as you describe. Once again, thanks you're a star!! :D
