Just bought this
Michael
Just bought this
Post by Michael » Sat, 21 Mar 2009, 5:38 pm
Hi I have just bought a Portafold and I'm looking forward to some comfort at Rod Runs this year. It needs some tidying up but could be used as is.
I'll let you know how I get on.
Mick
Your Portafold
Post by txfsealord » Sun, 22 Mar 2009, 6:54 pm
Hi Michael,
Does your Porty have 12" wheels?
I seem to have become the site 'wheel-anorak', I'm finding it very interesting, which rims the Rubery Owen company supplied with its axles.
Michael
Post by Michael » Sun, 22 Mar 2009, 11:42 pm
Hi Steve, Yes it does have 12 " wheels which I read in one brochure came fitted as standard.
Here are some more pictures of the van on my webshots album.
http://rides.webshots.com/album/5706204 ... host=rides
Mick
Post by vauxhallbitz » Thu, 26 Mar 2009, 10:33 pm
Hello,
Are the 12" wheels Mini wheels? If so, are they from an early Mini or a Morris Minor?
Fraser
Michael
Post by Michael » Thu, 26 Mar 2009, 10:37 pm
Sorry, I have no idea. Is there a way to check? and I'll have a look tomorrow.
cheers Mick
Post by vauxhallbitz » Thu, 26 Mar 2009, 10:59 pm
Hello Mick,
Thanks for that, I don't know is the short answer but hopefully someone will read this and enlighten us. I think the 12" wheels look better proportion wise as the 10" are just a bit too small for the wheel arches.
Will you be taking your van to the Nationals in July?
Michael
Post by Michael » Thu, 26 Mar 2009, 11:21 pm
Yes I'll be at the Supernats. I'll probably go to the Spring Nats at Drayton Manor and NASC Nationals at Ipswich as well as some smaller runs nearer home. Don't know about Billing yet as the site is a mess if its wet and too open to public. I'll be taking my Portafold to them all.
P.S. If I find anything out about the wheels I'll post on here.
12" wheels
Post by txfsealord » Fri, 27 Mar 2009, 7:56 pm
Hi all, I think the 12" wheels used on the early Portafolds were specially made by Rubery Owen, unfortunately. Certainly the 10" wheels are Rubery's own. Mini wheels have different offset, although they can be used - I have 'em on mine.
With the 12" size, the only car-type with the correct stud pcd would be Hillman Imp. These have more offset than the Rubery ones, so they'd clear the axle ends. Only late Minis had 12" wheels, with very little offset to them & I'm pretty sure they wouldn't clear the axle without quite a thick spacer. Minor wheels are 14". Austin A35s & A40s are 13".
Hope this helps
Post by Admin » Fri, 27 Mar 2009, 10:11 pm
I bow to Steve's far superior knowledge on wheels, but one thing I have found out is that Rubery Owen didn't just concentrate on making the trailer chassis running gear that our Portafolds use.
They also produced steel wheels on quite a big basis. Apparently the 13" 5.5J steel wheels (that currently adorn my Ford Anglia) and are known commonly as Lotus steels, were made by none other than...Rubery Owen Ltd.
Rubery Owen
Post by txfsealord » Sat, 28 Mar 2009, 7:44 pm
Oh, not half! Rubery Owen were a huge engineering company, making every kind of steering, transmission, chassis running gear for a great many British cars, as well as a vast range of engineering products for industry generally. They built most of the V16 BRM.....
